Коллеги, добрый день.
В Luxms версии 8.10.23 не работает запрос
в БД есть поле с типом Date
это запрос к БД из куба
select default.“v_Request54”.AFFECTED_ITEM as AFFECTED_ITEM,
default.“v_Request54”.CATEGORY as CATEGORY,
default.“v_Request54”.CLOSE_TIME as CLOSE_TIME,
default.“v_Request54”.“CLOSE_TIME_month” as “CLOSE_TIME_month”,
default.“v_Request54”.“CLOSE_TIME_year” as “CLOSE_TIME_year”,
default.“v_Request54”.DURATION_REACTION as DURATION_REACTION,
default.“v_Request54”.DURATION_REGISTRATION as DURATION_REGISTRATION,
default.“v_Request54”.DURATION_SOLUTION as DURATION_SOLUTION,
default.“v_Request54”.HPC_ARRIVE_TYPE as HPC_ARRIVE_TYPE,
default.“v_Request54”.HPC_CLOSE_MARK as HPC_CLOSE_MARK,
default.“v_Request54”.HPC_DIRECTION as HPC_DIRECTION,
default.“v_Request54”.HPC_GROUPSERVICE as HPC_GROUPSERVICE,
default.“v_Request54”.HPC_RETURN_TO_WORK as HPC_RETURN_TO_WORK,
default.“v_Request54”.HPC_SERVICE as HPC_SERVICE,
default.“v_Request54”.HPC_TIME_ACTUAL_END as HPC_TIME_ACTUAL_END,
default.“v_Request54”.“HPC_TIME_ACTUAL_END_month” as “HPC_TIME_ACTUAL_END_month”,
default.“v_Request54”.“HPC_TIME_ACTUAL_END_year” as “HPC_TIME_ACTUAL_END_year”,
default.“v_Request54”.HPC_TIME_ACTUAL_START as HPC_TIME_ACTUAL_START,
default.“v_Request54”.“HPC_TIME_ACTUAL_START_month” as “HPC_TIME_ACTUAL_START_month”,
default.“v_Request54”.“HPC_TIME_ACTUAL_START_year” as “HPC_TIME_ACTUAL_START_year”,
default.“v_Request54”.HPC_TIME_REGISTRED as HPC_TIME_REGISTRED,
default.“v_Request54”.“HPC_TIME_REGISTRED_month” as “HPC_TIME_REGISTRED_month”,
default.“v_Request54”.“HPC_TIME_REGISTRED_year” as “HPC_TIME_REGISTRED_year”,
default.“v_Request54”.HPC_TYPE_FEEDBACK as HPC_TYPE_FEEDBACK,
default.“v_Request54”.INCIDENT_ID as INCIDENT_ID,
default.“v_Request54”.OPEN_TIME as OPEN_TIME,
default.“v_Request54”.“OPEN_TIME_month” as “OPEN_TIME_month”,
default.“v_Request54”.“OPEN_TIME_year” as “OPEN_TIME_year”,
default.“v_Request54”.PRIORITY_CODE as PRIORITY_CODE,
default.“v_Request54”.SLA_DURATION_REACTION as SLA_DURATION_REACTION,
default.“v_Request54”.SLA_DURATION_REGISTRATION as SLA_DURATION_REGISTRATION,
default.“v_Request54”.SLA_DURATION_SOLUTION as SLA_DURATION_SOLUTION,
default.“v_Request54”.SLA_REACTION_BREACH as SLA_REACTION_BREACH,
default.“v_Request54”.SLA_REGISTRATION_BREACH as SLA_REGISTRATION_BREACH,
default.“v_Request54”.SLA_SOLUTION_BREACH as SLA_SOLUTION_BREACH,
default.“v_Request54”.HPC_CLOSE_MARK_INTEGER as HPC_CLOSE_MARK_INTEGER,
default.“v_Request54”.RESOLUTION_CODE as RESOLUTION_CODE
from default.“v_Request54”
в кубе это поле с типом PERIOD
на диаграмме включили фильтр по полю “Дата поступления” (OPEN_TIME)
и сразу при смене значений фильтра выходит ошибка
